Re: ca18det AFM wiring
From mandurah
hey bailz how did you setup the harness without running the relays
Posted on: 2009/12/30 12:28
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
will do. i will be making up a new loom soon anywayz, this is just so i can iron out any faults.. i am not running any relays at the moment, just running one for starter motor.. so i am sortin that out today, puttin in my relays and all that
Posted on: 2009/12/29 3:31
From Mandurah, Western Australia
Let us know if it works.
Posted on: 2009/12/29 2:47
key and barrel for the ca? or the 1200 loom?
Posted on: 2009/12/28 23:34
From mandurah
my do you know anyone who might have the under dash loom for the key and barrel cos all ive got is the engine bay loom
Posted on: 2009/12/28 14:53
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From mandurah
sounds good i wanna see wat it turns out like
Posted on: 2009/12/28 14:50
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
Hopefully get the ca outta safe mode so I can actually rev her up a bit
Posted on: 2009/12/28 14:43
I sure hope your right ;) cheers mate. I will drop round once I have the beast up and running fully :) hehe
Posted on: 2009/12/28 14:42
From mandurah
ok
A= green with yellow stripe
b= black with white stripe
c= black
d= green with black stripe
hope this helps
Posted on: 2009/12/28 14:35
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
How'd ya go? U will have to plug the afm in to see which wires go where
Posted on: 2009/12/28 14:29
