Re: GOT IT STARTED -BUT NO SMOOTHING ON IT
Valve clearance for intake & exhaust are the same.
Did you adjust the idle speed & idle mixture?
Posted on: 2010/1/4 3:36
From Sri Lanka
Hi DD
It doesn't have anti-dieseling valve to the carb ,are intake and exhaust vale clearance differ ? if so what is that, i remember user manual says similar value for both
thanks
regards
sumith
Posted on: 2010/1/4 3:11
From hastings,vic
check valve clearences??
Posted on: 2010/1/1 6:31
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
Congratulations on getting it started again.
Backfires are usually either too lean (Does your choke works) or timing is incorrect (Do you have a timing light, or can borrow one?)
If it cannot idle, it often is the anti-dieseling valve. Is the wire connected?
Posted on: 2010/1/1 5:24
From Sri Lanka
Hi Guys
Got my datto started , hope the timing is correct it is getting started at once, just before the start i get a backfire and also id doesn't idle on low rpm ,not at all smooth, i have fixed all vacuum also Any idea Guys ?
Thanks
Regards
sumith
Posted on: 2010/1/1 4:36
