Re: tacho 1200 ute
From Sydney, Australia
thanks will check out
Posted on: 2010/1/7 9:37
Re: tacho 1200 ute
Late ute tachometers are wired differently than early Datsun 1200 tachometers.
Early: 4-wire
One wire for induction signal (two wires in the harness) + Lamp & earth (ground)
Late: 3-wire
Lamp + Tach signal & Ground/earth
It works the same whether you have Datsun electronic ignition or not.
See Tachometer Wiring
Posted on: 2010/1/6 20:31
Re: tacho 1200 ute
From Perth WA AUS
Standard tacho is connected to + on the coil i think.
Posted on: 2010/1/6 13:54
Datsun 1200 2Dr sedan.
Re: tacho 1200 ute
no just factory tacho only has 2 wires every time you put on coil it cuts engine
Posted on: 2010/1/6 11:36
Re: tacho 1200 ute
From perth airport
should still work or if your installing it now google tacko wireing and its 4 wire to hook up ya cant realy go wronge dude :)
Posted on: 2010/1/6 11:27
perth airport parking
Datsun 1200 ute A14
tacho 1200 ute
just put in 1400 motor in my 1200 ute have electronic dizzy need help to get tacho working
Posted on: 2010/1/6 11:23
