Re: Front strut measurements. HELP !!
From Newcastle nsw
Excellent. Thanks heaps. dont happen to also know from bottom of struts to the strut top where it contacts the body??
Posted on: 2010/1/14 10:54
From cranbourne, vic
441mm - strut tube base (mounting surface) to the top of the strut tube.
standed spec monroe oil insert:
440mm - compressed.
637mm - uncompreessed.
419mm - insert body lenth.
195mm - shaft lenth from top of insert body to below thread.
25mm of tread.
656mm - strut with monroe insert uncompressed.
459mm - strut with monroe compressed.
Posted on: 2010/1/14 7:33
82 1200 ute - daily
89 R31 H.M.A.S. Skyliner - drifter
197? 1200 coupe - new drift project.
85 CMA81 nissan/ud 9.5ton banana back - tow pig for the drifter.
From Newcastle nsw
Can someone measure for me the total length of a standard strut? From under the strut tube, to the top of the strut top?? Also the length of the standard strut tube, from under the bottom to the top edge, and does anyone have the measurements of the stanard strut inserts?? body length, shaft length comressed and uncompressed etc?? i couldnt find this in the tech wiki, but then again i am not to good at navigating through that thing lol.
Thanks
Josh
Posted on: 2010/1/13 23:39
