Re: Which timing cover?
From Townsville, Qld
plus this poxy epoxy didn't hold when I checked it this morning, it had enough curing time.
Posted on: 2010/1/19 2:27
ah screw that, I'm grinding this stuff off and finding someone in Townsville with it. I only have 3 covers not bolted to blocks at the moment and I don't want to dismantle the other 2 blocks just to find out
Posted on: 2010/1/19 1:29
149C is borderline for this use. The coolant wil usually be less 110C -- on average -- but could get hotter in spots. Especially when you turn off the engine.
Since all 1973-2009 timing covers are identical, why not just get another one?
Posted on: 2010/1/18 19:24
I didn't think of it but if I did grab one of somebody I'd be spending the same amount of time cleaning and painting it.
I went looking for JB weld epoxy ( said that as a refence but told them what it was) and I got the run around from most places I went to which seems goes to show that:
A. some people have no idea what they're selling.
B. they don't know who I am
Anyway I picked up a two part chemical resistant multi metal epoxy rated to 149degrees celcius, is that bordering on what coolant temps would be?
That's just after I applied it. I used a grinding bur to roughen up the surface and dig out the holes a tiny bit then cleaned it with carby clean.
edit: oh, and
C. it's all a government orchestrated scam to keep me out of my Datsun
Posted on: 2010/1/18 13:31
From NZ
Surely someone must have a decent one lying around. I must have half a dozen - if I was closer I'd give one to you.
Posted on: 2010/1/18 10:17
1200 Coupe Racecar, mid-mount A13, C/R 60L g'box.
Previous "Datsuns": B310 sedan worked A13. B310 coupe A14/dogleg 5-spd. 260C sedan, L26, 3-spd man col chng, 6-seater great tow car!. VL wagon, RB30, 5-spd. Nissan Bluebird SSS U13, SR20, 5-spd.[i...
From South Africa, Bloemfontein
Get it welded up. My A12 made a pin hole due to corrosion. Luckily to the outside and not to the inside of the engine. They just welded it up and used a di-grinder to get it like it is suppose to be before corrosion.
Posted on: 2010/1/18 8:01
1977 Datsun 1200GX
From Adelaide, Australia
I made a mount for the water pump belt cover on my mums TP magna with JB weld after the one cast into the alloy valve cover cracked off, even the bolt threads into it nicely after running a tap into it.
Posted on: 2010/1/18 6:25
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Las Vegas USA
Get some two part epoxy like JB Weld and fill in the gaps, then use some emory cloth and smooth and shape as needed. Here is a list of things we fixed with two part epoxy: front tranny mount on VW Baja Bug, cracked fule tank on BSA 650 corrosion, divet on A14 deck between 1 & 2 cylinder, the radiator on my 2001 YZ125 and numerous cases on MX bikes.
Tom
Posted on: 2010/1/18 4:18
Those sharp chunky bits from crap in the cooling system or the pump crapping itself. The pump crap itself on me once but at the time I don't think I looked in the housing when replaced it. I don't want more of those chunks coming loose.
Posted on: 2010/1/18 3:01
What's wrong with the one that's not corroded?
Posted on: 2010/1/18 2:54
