Browsing this Thread:
Re: GX Compatible Extractors/Exhaust
From NZ
Here in NZ we have (had?) two styles of 4-1 extractors available.
1. "twin carb" - centre two pipes (ie 2&3) go over the two outers (1&4). To suit twin sidedrafts (Webers/Delortos etc)
2. "Single carb" - centre two pipes go under the outers. Suit std single carb manifold.
I've used both. Same pipe diametre. Don't think the single carb style would flow quite as well due to them needing to 'tuck' down a little tighter where they exit the head. Having said that I'd say they run well with GX set-up.
Posted on: 2010/1/20 10:27
1200 Coupe Racecar, mid-mount A13, C/R 60L g'box.
Previous "Datsuns": B310 sedan worked A13. B310 coupe A14/dogleg 5-spd. 260C sedan, L26, 3-spd man col chng, 6-seater great tow car!. VL wagon, RB30, 5-spd. Nissan Bluebird SSS U13, SR20, 5-spd.[i...
From Perth WA AUS
Heat shield does just that, always good to have. I say modify it it you have to but keep it or make a custom one. Just my 2 cents worth!
Posted on: 2010/1/20 10:16
Datsun 1200 2Dr sedan.
From ACT
I would but the throttle return springs are mounted on the heat shield.
When I first got em I had no heat shield and couldnt figure out for the life of me where the return springs mounted.
If I had the skill I could make a replacement one that would maybe fit, in fact I could probably do that with enough time but I need new extractors to run the su's anyway, there's like 2/4mm gap between the fuel bowls and #1 & #4 exhaust primaries
Posted on: 2010/1/20 10:05
Now riding dirtbikes:
Lots of A series Datto stuff for sale
From Melbourne, Australia
lol i trimmed the corners off the heat shiel, but that was about 8years ago when i figured i could get another easy enough, i wouldnt be trimming a heat shield now, better to just not run one?
Posted on: 2010/1/20 10:00
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Yes, the A14T manifold won't outperform extractors, but it's still a good unit, good flowing, last forever, dont' leak, and a lot quieter than tubular steel headers.
Posted on: 2010/1/20 8:46
From Perth WA AUS
I have an A14 exhaust manifold similar to the GX but single outlet.
Posted on: 2010/1/20 8:35
The factory GX manifold is better than extractors. You can lenghten or shorten the down tube is you want to tune it for performance.
You can get big-tube extractors for the A-series that will outperform it at high RPMs, but those are even less likely to fit.
Posted on: 2010/1/20 8:30
From ACT
Heh heh yeah $75 US inc post is a great deal!!
you wanna sell the genies unfamilia?
Posted on: 2010/1/20 6:38
my old genies fit, just trim the heat shield a little on the corners.
Posted on: 2010/1/20 6:34
From Selah, Washington
the thing of it is I paid $75 US for my exhaust manifold...including postage from AU
I got lucky
Posted on: 2010/1/20 6:33
