Re: Fuel tank help ?
From sydney
Thanks guys for the help cheers.
I was going to run a fuel cell in the back tray of my ute with external pumps under the car.
Posted on: 2010/2/5 22:13
PROJECT:DATSUN sunny sedan CA18det
From SE Melbourne
Guess you gotta decide if it's internal or external fuel pumps....internal is neater, external is easier (no chopping up of welding of fuel tank)
I roll this way....
Surge tank & lift pump
http://mildman.datsunprojects.org/images/100_5221.JPG
EFI pump
http://mildman.datsunprojects.org/images/100_5156.JPG
Theres a bunch of filters around too - more pics on my dodgy website
Posted on: 2010/2/5 12:44
Mildman, Datsunless
From Brisbane
i welded a large washer in my filler neck, to reduce it down
Posted on: 2010/2/5 11:51
AWD the way to go
From Tamworth , NSW
the filler hole on my zed was about 555-60mm in diameter. you cant miss it.
the old super nozzles must have been as big as the hi-flow diesel ones.
Posted on: 2010/2/5 10:53
From Bendigo, Victoria
They were big , needed 2 hands to hold them.
Posted on: 2010/2/5 10:33
From Melbourne, Oz
HAHAHA! Im 22 and I have never seen these larger fillers?
Posted on: 2010/2/5 10:26
"I hav achieved wood"
From Tamworth , NSW
dont think you would need a new fuel tank, unless capacity is a worry.
and with the filler hole, it only has to be modified so only unleaded size nozzle will go in, but now we dont have super pumps with the larger nozzle i dunno if it would be an issue.
someone correct me if im wrong here.
Posted on: 2010/2/5 9:59
From sydney
ANyone?
Posted on: 2010/2/5 9:56
Fuel tank help ?
From sydney
Im looking at starting the fuel setup on my CA18DET 1200 ute. I just wanted to know what i have to do to run unleaded fuel ? can i used the same tank ? do i need a new fuel neck ? thingfs like that.
I'm going to run to aftermarket fuel pumps if that helps.
Thanks
Posted on: 2010/2/4 5:17
Edited by FRKYCA on 2010/2/4 7:39:14
