Re: Alternative engine to install in Southern Calif.
Just go with an A14 or A15, you will be amazed how much more powerful it will be.
Get the engine, transmission, driveshaft and rear axle "pumpkin" from a B210 or B310 (Datsun 210). It is completely bolt in to B110 except for simple bracket mods.
Using L-series or Toyo engine will require fabrication, shifter location is usually back 3-4 inches, plus you need a rear axle assembly swap.
Posted on: 2010/3/3 20:58
Not too shy to talk
From Garden Grove, Ca. USA
We have owned a 1200 for 29 years.
Just blew up my A12A.
Need a bit more power on these freeways out here. Would it be easier simply to have it bored out to like a 1.5 verseus putting in a L series or a T-3 Toyota.
Would those two, L series or T-3 require too many modifications to motor mount and drive train?
Posted on: 2010/3/3 16:53
