Re: Ca20 gearbox versus stumpy box on sr20 in 1200
From Maraylya nsw
thanks alot for your help
i think ill go with the 71c box
hopfully wont take to much to get in
Posted on: 2010/3/13 12:20
sr20de out of s13 written of silvia under way
making progress on the 1200 coupe;)
From Geelong, Vic
r30 boxes arent that hard to find, if your buying from non 1600 circles anyway.
id personally go with the 71c as its a nicer stronger box, i'd get one from an R31 sklyline/pintara or VL commodore as they have the same ratios as the sr turbo box, should be just as strong, are a couple of inches shorter and are dirt cheap. got my one for $150
Posted on: 2010/3/13 2:59
From NW Sydney
From my experience (have used both in 1600s) its a bit like this:
Rare MR30 box is a better fit and doesn't require floor cutting, but is MUCH more expensive (Typ $300-700 to buy one, and it will prob need a $$ rebuild due to age, though you can be lucky)has non-ideal gear ratios for a 4 cyl.
Common Bluebird or Gazelle CA20 box is cheap (ie case of beer cheap) has good ratios and will take plenty of abuse (unless frequent drifting and drag racing is your thing). Still, if you break one, it's pretty quick and easy to swap out. Plus given the cost comparison with MR30 box, you can afford to have 6-8 spares in stock.
Posted on: 2010/3/12 23:53
SR20DET 1971 Datsun Bluebird 1800SSS Coupe - 11.58 @ 122.40 MPH GT2871R PLMS NIStune
Historic 1971 Datsun 1600 Wagon - L series nostalgia
Historic 1967 Datsun 1000 Wagon - A series resto
From sydney
I have just bought a gazell with a ca18det in it for my 1200 which as a ca20 gearbox behind it i was planning on using it but after driving the car it feels nice while crusing but at hi rpm it dosent shift very well at all and is still a pretty big box bigger than the stumpy so im just going to do the mods and fit a s13 box
Posted on: 2010/3/12 21:23
From mandurah
suck it and see ,if you have one of both then see which one is more suitable and use it
Posted on: 2010/3/12 14:15
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Maraylya nsw
help please!
Posted on: 2010/3/12 13:28
From Maraylya nsw
Hey guys
as posted I'm starting a thread about ca20 gearbox found out of an 85 model bluebird versus the imphamous expansive mr30? Skyline stumpy box.
Just trying to find which one is better, better fit, stronger gearbox etc etc on an sr20 in a 1200.
Any information much apricated.
Cheers andy
Posted on: 2010/3/12 7:45
