Re: Electronic dizzy problems
Yes, the resistor is 1.3 ohms, so if put inline, no coil will be able to burn it out.
Stock 1200 coil (points-type): 1.17 to 1.43 ohms
Stock 1200 balast resistor: 1.3 to 1.7 ohms
Stock B310 electronic coil: 0.84-1.02 ohms (high energy)
Posted on: 2010/3/14 2:31
Edited by ddgonzal on 2010/3/14 3:19:03
From Brisbane, Australia
I also have one from mal, it runs fine now for a couple of months. I still have the resistor in with it. Tacho is hooked up across the resistor.
Hope the info helps.
Geoff
Posted on: 2010/3/13 22:25
The crane coil pack takes too much amperage for the electronic distributor controller.
You should use a coil system of no lower than 0.84 ohms.
Posted on: 2010/3/13 20:19
Ye mate.
I reckon you got it in the wrong hole aye???!
Dirty-dizzy-burner you dan. Them are good dizzies. Your engine must prefer fairy dizzys, you know, the pink ones.
Posted on: 2010/3/13 15:26
From SA
yeah i dunno,
chris had one of those dizzys running in his 1000 for about a year, so its not that dizzy, but my ute managed to cook it...
any one else have any input?
i apperciate your help BRUTE thanx very much mate
cheers
Dan
Posted on: 2010/3/13 11:51
full resto: 1971 ute check it out in projects
full resto: SR20 1973 coupe check it out in projects
Go Hard Or Go Home
From Bathurst - NSW
I've had a unit fail on me twice also (aftermarket), turned out it was the dizzy itself, sounds like you're getting the same reception!
Posted on: 2010/3/13 11:22
From SA
yes straight 12v to the coil... no tacho or anything at all
im stumped ???
cheers
Posted on: 2010/3/13 11:18
Go Hard Or Go Home
From Bathurst - NSW
No, took mine out also. Are you running 12v to the coil, and nothing else from the coil, ie tacho, etc.
Posted on: 2010/3/13 11:12
From SA
no the the guy at OG speed shop told me to take it all out, should i be running it ?
cheers
Dan
Posted on: 2010/3/13 11:02
Go Hard Or Go Home
From Bathurst - NSW
Still running your ballast resistor?
Posted on: 2010/3/13 10:55
