Re: Any compatible dash for B210 ?
From Townsville, Qld
if only there was an abandoned Datsun factory with lots of parts still around
Posted on: 2010/4/8 10:09
620 trucks use the same gauges as Datsun 1200, though the lenses are different.
B110 or 620 gauges might fit into a B210 round-gauge dash.
Posted on: 2010/4/7 18:53
I thought L series gauges would be a better bet for the B210 round gauge, how common are they over there? like 710's or 620 utilities
Posted on: 2010/4/7 15:21
Unknown. The B110 rectangle dash and round dash use a different wiring harness, so they do not simply connect up.
Posted on: 2010/4/7 7:29
From Sri Lanka
Hi DD
Thanks , Here i have seen only 2 or 3 B110 , here we got so many B210
only,if i buy rectangle guage(b210) with cover will i be able to hook it without
any modification to the panel ?
Thanks
Regards
Sumith
Posted on: 2010/4/7 6:08
That is a B210 GL dash, as used in the Japan market.
Most B110 have similar round gauges, such as my sedan.
From the looks, I would guess the B110 gauges will fit your dash. Also the entire B110 dash assembly reportedly fits in a B210.
Posted on: 2010/4/6 8:16
From Sri Lanka
Hi Guys
I have got verry different Dash board cover than usual 1200s here, i got round guage one, but almost all 1200s here got rectangle guages, any othere compatible dash from mmc or toyota or any other nissan model available ?
Thanks
Regards
sumith
jpg  1.jpg (18.75 KB)
10994_4bbad43e07ad0.jpg 352X288 px
Posted on: 2010/4/6 7:27
Yes, you can fit one from another B210, or from a B110 with some wiring modification.
Posted on: 2010/3/27 1:32
From Sri Lanka
Hi Guys
what will be compatible dash board for b210, i got fedup with my dash board it is working sometimes
and not at all somtimes,now both Temparature and petrol guages are not working at all, it has got some broken pins and paths on the Board, it is not repairable any more ,
Thanks
Regards
sumith
Posted on: 2010/3/26 7:50
