Re: Datsun 1200 Heater Box!!!
From Brisbane
i have a couple in the back shed, i'm in Alex Hills if you want to come around and have a look at the cores you are quite welcome.
Posted on: 2010/4/9 13:18
AWD the way to go
From Adelaide
hey mate,
i got a a heater ute. im in adelaide tho, it worked 2years ago when i took it out but since then its sat in the corner of the shed
if ur keen email me Ben_edwards87@hotmail.com
Posted on: 2010/4/9 8:14
From Sydney, Australia
drain water from radiator into a bucket with heater knob set to HOT.
remove air ducting pipes for windscreen
2 bolts in firewall, 2 bolts on top.
carefully remove clip for cable on flappy thing for demister. DONT LOSE CLIP
Disconnect the 'ROOM' bottom flap cable.
unplug the 2 wires for fan speed control resistors.
disconnect hoses that go through firewall.
remove unit from car.
Probably good to get it all out and give it a clean.
Depends if you are replacing the whole box, or just the heater core.
If you are just doing the heater core, 2 phillips screws and a couple of clippy things you can flick off with a small straight blade screwdriver. Getting to the rear hoseclamps can be challenging without removing the whole unit.
Posted on: 2010/4/9 4:28
From Redlands Queensland
Hey does any one have a datsun 1200 ute working heater box for sale? As i have to replace my old one any tips on taking it out?
Cheers Cam
Posted on: 2010/4/9 2:01
