Re: Turbo A14
From sydney.nsw
just trying to help,just like u asked.
Posted on: 2010/5/14 10:41
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Re: Turbo A14
Quite a regular
From Perth
right...
Posted on: 2010/5/14 10:27
Re: Turbo A14
From sydney.nsw
if u go a15 i have a set of forged a15 pistons/rings with 18cc dish to lower comp. i suggest low comp depends on boost/flush deck hieght/good head gasket/head stud kit/nice ported head/good springs/balanced/cam 277in/284ex 112lode sep.if i can help pm me. cheers
Posted on: 2010/5/14 8:34
Re: Turbo A14
From Rosewood, QLD
kill his head off!!!
Posted on: 2010/5/14 5:08
1971 B110 sedan project.
2012 Nissan Micra daily.
Re: Turbo A14
From Lethbridge, AB, Canada
sakura... ur an idiot
Posted on: 2010/5/14 4:57
'73 Datsun 1200 Sedan Turbo A12
Turbo A14
Quite a regular
From Perth
Hey, what mods can i do to the short motor of an A14 to suit injected turbo set up?
Was going to balance it but is there any other little tricks that will increase drivability but not effect how strong it is, ie. is there a rebuild kit or similar?
What sort of cams do you think would suit the size motor with a turbo?
Would it be worth lowering compression via piston height and use the bigger cylinder head to get more flow?
Cheers
Posted on: 2010/5/13 6:08
