Browsing this Thread:
1 Anonymous Users
Re: HELP!!! fuel line is blocked! |
the wire just bends, i could figure out the problem so i think spending so much time trying to start it,(running the fuel pump) got it really jammed in there.
Posted on: 2010/5/13 15:04
73' 2-door sedan
hey champ,
if you have some spare fuel line laying around then yeah you can replace it, depending where the block is, we used to use a thick gauge wire, and a air compressor. slowly feed the wire thru, untill it comes out the other end, the get the air compressor with the blow gun attacthment (after you pull the wire out) and blow it thru.
ben.
Posted on: 2010/5/13 6:55
the fuel line coming from the bottom of the gas tank is clogged. does anyone know how to fix it or replace the whole line?
Posted on: 2010/5/13 4:25
