Browsing this Thread:
1 Anonymous Users
Re: Misfire engine ,cought to heavy rain |
From illawarra, nsw australia
Also you said about cleaning your carby if you know how to do this give it a try!
Posted on: 2010/5/24 11:13
datsunless. for now
Hmm it might be worth draining fuel and putting in a fresh 10 litres? How much fuel is in your tank?
You said your air filter and dizzy cap was wet a wet airfilter would meen there is a high chance that at some stage there would be water in your cylinders
so as i said before make sure your spark plugs are in a good state. water in a dizzy cap makes the electrical contact points corode very fast make sure the little nobby bits on the underside of your distributor cap are clean also the rotor button, clean the breaker points also.
i know i have gone back and forth between fuel and electrical but imo trying everything is worth it in your current situation
goodluck sumith and remember its a datsun! Chances are its gunna be good as gold with some time and patience
Posted on: 2010/5/24 11:11
datsunless. for now
From Perth WA AUS
Maybe water in the exhaust system? (nah surely not) If you have checked the things listed above I'm stumped!
Posted on: 2010/5/24 10:13
Datsun 1200 2Dr sedan.
From Sri Lanka
Hi juniorjay
I have no idea what was the water level in the road ,but it was bit high like 1 feet up,do i need to drain my fuel tank or just cleaned the fuel pump and the carburetor would be enough ? i cant accelerate the car, it makes a sound and stops.
Thanks Regards Sumith
Posted on: 2010/5/24 9:56
check all points where there is electrical contact
eg all spark plug leads connections, coil to distributor. maybe even check spark plugs, clean and reset. ( they wouldnt have been effected by the water but its worth checking to rule out any possibilities )
if you have time reset points
if it is electrical it would have been fixed by checking all of the above. could be water in fuel? how high did the water reach on the side of your car?
Posted on: 2010/5/24 8:39
From Adelaide, Australia
check water in the leads and coil?
Posted on: 2010/5/24 5:42
parts needed: GX air filter box. for sale, stanza steering wheel, 1000 gloveboxes lids
From Sri Lanka
Hi Guys
My datto got into flooded water, still it was running but i had alittle miss in the engine, last Saturday tried to start it doesn't start, removed distributor cover, air filter they were bit wet and cleaned and kept them on hot sun,cloned the platinum point(dwell) plugs etc, after that it was started, but always have a miss fire from the exhaust with puff puff sound.what would be the case guys any think else that i can do ?
Thanks Regards sumith
Posted on: 2010/5/24 4:49
