Re: A few issues with my datsun 1000 ute, please help :)
From Freo
you can fit a mechanical switch on the pedal, some have the hole already..
Posted on: 2010/5/31 11:40
A15 PSI Project Motor
'72 CB750k,
From Wagga Wagga, NSW
Quiet ryan you redneck!
Its old to me haha im 17!
Posted on: 2010/5/31 11:25
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
i thought you might say that
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
Oi! I'm 24 thanks.
Posted on: 2010/5/31 11:18
From Rosewood, QLD
yes do some cleaning you animal.
Posted on: 2010/5/31 11:14
1971 B110 sedan project.
2012 Nissan Micra daily.
Ahh yes, thankyou wise elders of the datsun 1000 appreciation comity :D
Posted on: 2010/5/31 11:09
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
The lights are operated by a pressure switch mounted on the fire-wall, it kinda looks like a splitter (well it is) but it has a couple of wires coming out of it. When you apply pressure it is meant to activate the lights.
So I suppose two things can be wrong, mechanical fault (poor pressure) and electrical fault (switch/wiring).
Sounds like all it needs a little clean-up and a few bits and bobs replaced.
Posted on: 2010/5/31 10:57
Thankyou wise dundee ! now how do i go about getting my brake lights to work when i apply ANY pressure to the pedal?
Posted on: 2010/5/31 10:54
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
From Freo
the temp and fuel gauges.. needs a new voltage regulator.. I can get new ones..
do the brakes propperly, replace the wheel cyl's and adjust the brakes.. you'll be more than happy with the results..
the stock drums work well when they are fresh..
Posted on: 2010/5/31 10:39
'72 CB750k,
Thanks reuby :) also my brake lights only work under very heavy pressure, not everyday braking when they need to be seen, is this adjustable?
ALSO *rolls eyes* The temp and fuel guage rarely work and when they do they raise to the measured fuel height or engine temp then back down again :S
Posted on: 2010/5/31 9:39
Ryan(Zigzag) says:
mmmmm men
Jake(tuf-110) says:
Ryan(Zigzag) says:
its raining men
Jake(tuf-110) says:
oh its your day
From Adelaide, Australia
i had the same problem with my 1000 ute indicators. after trying 4 different switches it finaly worked.
Posted on: 2010/5/31 8:58
parts needed: GX air filter box. for sale, stanza steering wheel, 1000 gloveboxes lids
