Re: heads (painful veiwing)
I just need the skill and time but have the motivation :)
Posted on: 2010/6/5 16:23
That's the way D.
Go for it.
Posted on: 2010/6/5 15:14
Anything is possible if you have the time, skill and motivation.
I just would like a high port A series head that just has some crazy
angle to feed into the valves all made from a cheap round port.
Posted on: 2010/6/5 14:10
From Tamworth , NSW
l31dett
24 pages on the l31dett build.
Posted on: 2010/6/5 12:36
From mandurah
wait there was a guy that built a L31DETT and put it in a fairlady
he used 3 KA24 heads and cut them up to form a single 6 cylinder twin cam head with 4 realy big bolt/studs that bolt the whole thing together and he then has custom cams made aswell ,but im not sure how he seated the heads together but it put out around 700 horse power ,from memory (correct me if im wrong )
Posted on: 2010/6/5 12:03
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From windsor, sydney
I have heard of that in the past as well but dont think it would be achievable. there are too many water channels and internal webs to weld successfully . and with the availability of cnc porting machines becoming more common its probably easier to go that way with a standard head. But if you want to go all out why not do some research on motorcycle heads and see if you can match the bore spacing with say a suzuki huabusa twin cam head and mount that on a aseries block , that would be a good project!
Posted on: 2010/6/5 11:45
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
From sydney.nsw
u would need to use a gasket between the 2 halves,unless hes a magic welder. how do u weld up inside around water jackets. cheers
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
From Christchurch NZ
Wow this thread went off on a tangent. I agree with much of what was said though.
Back on topic though, I've wondered recently about the plausibility of making a scratch built head from two pieces. A bloke I know once told me of someone he knew who had cut a head in two, and then welded it back together after porting it out .
Posted on: 2010/6/5 11:29
Forced Induction!
All hail A-Series.
Hall Yeah!
Posted on: 2010/6/5 11:22
Don't worry too much, all the trades and works and jobs will all come back eventually. When things start getting sparse on the fossil fuel side of things ALOT of things will change. Transportation costs for goods will skyrocket and so will the prices of the goods themselves. I reckon you might just be able to get your vacuum cleaner mended too, instead of having to by another cheap POS because fricken' fairy-lah-dee-dah-dysons cost too much.
It won't be for a good 30 years though I reckon (before you start seeing jobs come back)
I don't think tradies make more, it just depends on what you do and where you go.
I worked in a mine sand-blasting #OOPS#plants (sewage tanks) for a grand a day, 10 hr days. The following week I was sitting in an office drafting and drawing because I mentioned to one of the blokes (over a couple of beers)that I had done alot of work with Autocad. The money was about the same, a little more but both types of work require a level of skill.
Who can really say which is more, which is better or what not.
Posted on: 2010/6/5 11:20
(1) 2 3 »
