Re: best spot for boost gauge line?????
From the central coast, nsw
there is a spot just after the throttle body for 1 on inlet manifold, dont tee into others. option 2 get a threaded nipple with a m6 by 1.25mm thread drill into ur manifold 5mm drill bit tap thread, and bam u have a a vaccum source just for ur boost gauge remember to put grease on end of drill bit to catch all swarf n a vaccum cleaner
Posted on: 2010/6/3 13:38
From Kingsley, Perth, WA
Into the inlet manifold/plenum. You want the ACTUAL boost going into the motors intake runners. Never T into anything else, because if you have a boost leak on the "anything else" or the guage hoses, you got problems
Posted on: 2010/6/3 2:21
From sydney
T it off the fuel pressure reg
Posted on: 2010/6/2 23:18
From hastings,vic
boost guage shold hook to manifold
Posted on: 2010/6/2 15:06
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
From brisbane
as it says.. just got a boost gauge for my ca and want to know the best spot to hook up from???? of the line from the wastegate????
Posted on: 2010/6/2 11:56
A15 1200 ute, 77 mini -b16a honda vtec project
