Re: Datsun 1200 GX carb
I don't know what to do if you have a good needle. Try the SU troubleshooting pages on the Web, they have some good advice.
Posted on: 2010/6/7 18:56
From South Africa
Hi Thanks for the reply. I have repalced the needle and one carb is perfect while the other is a bit tight on the fall. I want to send you the pics but they wont attach to this message.
What else can I do.
Regards
Morgan
Posted on: 2010/6/7 16:43
I don't see the pictures?
having trouble to centre the needle jet
In this case, replace the needle with a new one. That is the recommendation from others. Almost for sure the needle is bent.
Posted on: 2010/6/6 19:07
Datsun 1200 GX carb
From South Africa
I have a 1200 GX carb (see attached pictures) having trouble to centre the needle jet. The nozzle jambolt seems to be fixed in this throtle body. Does is move, if so how do you open its. If not how do you set the needle.
Regards
Morgan
Posted on: 2010/6/6 17:37
