Re: need some help
OK, it's not so simple.
B310 A15 & A14 exc van
B310 van
B310 A12
all use different brakes in Japan
In USA B310 there are two different types.
Which does your B310 have:
or one of these?
Or a Aussie PBR type?
Or this type used by some (but not all) Stanza?
Posted on: 2010/6/10 7:45
Re: need some help
center hole?
ACD122 is for B110 pads.
Japan-built Stanza some use ACDELCO 17D117, which is similar but wider:
This is what Japan-built B310 use. B310 with A12 uses a smaller pad. Stanza didn't come with 12" wheels.
Some USA stanza use a different shape pad altogther.
Aussie-braked Stanza uses a totally different setup.
Posted on: 2010/6/10 3:09
Edited by ddgonzal on 2010/6/10 3:40:55
Re: need some help
thx!
and last question...what offset and what size of central hole ?
Posted on: 2010/6/9 21:23
Re: need some help
From Nyngan, nsw Australia
B310 1979-81, PBR (part no: ACD122) ACDelco
Honda SE Civic 1500 1973-78 (aust)
1.2 EB1, EB2, EB3, SB (NZ)
also use the same pad
Posted on: 2010/6/8 0:51
living is good,.....
need some help
which part number for brake pads(datsun b310)?
Posted on: 2010/6/7 21:29
