Re: S13 Adj Strut Tops
From W.A.
Here is a couple of pics. they are nothing fancy but did the trick.
jpg  strut top.JPG (35.75 KB)
8427_4c21b5e5ddb66.jpg 640X480 px
jpg  strut top1.JPG (26.30 KB)
8427_4c21b5f7d1f52.jpg 640X480 px
Posted on: 2010/6/23 8:23
From south coast nsw
any pics jeffro j?
Posted on: 2010/6/22 20:50
From Adelaide
excellent, thanks for the tips. have already opened out my holes on the body to fit the current struts. cool, definitely an option then.
Posted on: 2010/6/22 14:32
From Townsville, Qld
same deal really srb, I the cusco set in my pictures disn't need any filing to fit in there but I would use dome top nuts on the adjusters like I'm running in my daily so I can put the caps on easier.
Posted on: 2010/6/22 6:21
From RAdelaide
Is this the same for 120y?
Posted on: 2010/6/22 5:27
"My mind is a raging torrent, flooded with rivulets of thought, cascading into a waterfall of creative alternatives." - Hedley Lamarr, Blazing Saddles
From W.A.
I made a new plate up, not adjustable but got maximum camber out of them. mine where tein.
Posted on: 2010/6/22 5:24
you use them 180deg around so basically it would adjust for positive camber used like this in a s13.
some people machine the top plate to get more adjsutment from them in a 1200. also i had to lightly file the dags on my strut holes in the car to install them. Only because the bolts had a bigger od then the stock bolts.
apart from that no mods. i didnt machine mine at all, and with late ute ball joints get almost neg 1deg (i adjusted mine for camber and castor though).
with stanza ball joints i get an extra deg of neg camber easy.
Posted on: 2010/6/22 5:13
S13 Adj Strut Tops
From Adelaide
Just wondering what the deal is with using s13 camber tops in the 1200. I know I have seen a few set ups with them, but pretty sure they need to be adapted.
Anyone know the full story?
Can get some cheap, otherwise will pony up for some new 1200 ones.
Posted on: 2010/6/22 3:17
