Re: wtb t25 oil and water lines
i understand just want to be certian b4 cutting and welding and dont want to stuff nething as i only have 1 a14 sump to mod
Posted on: 2010/7/16 8:26
Car free
From Armidale N.S.W
All this stuff can be found on ebay as you've alluded to nick you just need to mod it to suit or use the bits you want and put aside the rest. Even rebuild kits are on there for T25 estyre the shaft play isn't generally caused by the shaft its the bush/bearing that wear they even offer a How to on rebuilding it, well one member does.
Posted on: 2010/7/16 3:07
73 1200 wagon SOLD
From mandurah
im just goin to cut the side out if an old CA sump that i found out the back of the shed and then braze it to the side on the A12 sump
my turbo has a fair amout of play in the shaft but i need to know ,can i buy a new spindle shaft and bushes to remove the play in the shaft ,or will the play go away once i get oil pressure ?
oh and sorry for hijacking your thread nick and nick
Posted on: 2010/7/15 14:37
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Geelong, Vic
yeah tap water from heater lines would possibly be easiest, or just bottom radiator hose and block like you said
T the oil feed from the oil pressure switch, and just weld a pipe into the sump for the return
Posted on: 2010/7/15 14:21
ok so i just want to feed the turbo the stuff it needs on the a14 what would be good to use as im very very new to the turbo world. where do i get oil pickup from?? and how do i setup water feed and returne?? is there places that will work best if i hook them up to??
ie supplie water say from bottom hose radiator and returne at rear of head via heater inlet of head
ie oil pressure swith splitter feed to turbo and returne to sump or oil gallery in block??
maybe i should post this in main :)
Posted on: 2010/7/15 13:22
Car free
From Geelong, Vic
could use something like that, silvias use steel lines with banjos on the end of them that are really to suit the engine more so than the turbo
Posted on: 2010/7/15 12:56
Posted on: 2010/7/15 12:54
Car free
what do stock silvias use?? thats wat im after i think just need to fit the t25 to a14 unless u have another idea nic
Posted on: 2010/7/15 12:44
Car free
From Geelong, Vic
i think ive got one, you would need to braze it to some copper pipe or something so you arent running rubber hose next to the turbo though
Posted on: 2010/7/15 12:22
yeah but time to get to the wreakers is hard i work too much to get there.
thats why i thought id put a wtb on here and see if someone has them spare
thanks nik 4 the info but
Posted on: 2010/7/15 11:55
Car free
