Re: Weird Electrical situation ??. Fixed.
From Armidale N.S.W
Yeah so after that load of crap from the guru lets click on his link for debt management. NOT
Posted on: 2010/8/2 10:41
73 1200 wagon SOLD
From Perth WA AUS
Good one, was that spam or not?
Posted on: 2010/8/2 9:16
Datsun 1200 2Dr sedan.
From ACT
As Andy has fixed his situation I see no harm feeding the green stunted one.
I found it sorta funny that he's right if you think about it.
Seeing as Andy's energy supercharge got misdirected causing an unpredicted electrical situation.....
Posted on: 2010/8/2 8:41
Now riding dirtbikes:
Lots of A series Datto stuff for sale
toot toot (with ign off) i say
Posted on: 2010/8/1 15:05
From hastings,vic
sweet
Posted on: 2010/8/1 14:08
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
From Armidale N.S.W
Just to add i also had a lot of other wires arse about once compared to the other dash i have. We fixed horn and brake light situation but turned out i had blinkers with the ignition off. All reconfigured and sorted.
Posted on: 2010/8/1 14:04
73 1200 wagon SOLD
From hastings,vic
check to see if any thing works with key off
if somthing works thats not ment to swap wires on
back of fuse box with brake/horn wire
(spade ternimals on back of fuse box)
mine is wrong,indicaters work with key off
if all fails give me a ring
Posted on: 2010/8/1 13:41
From Armidale N.S.W
Thanks to another complete dash i figured out what you mean tommo. So i swapped the thick white wire (feed i assume) with the thick black wire (assume its the earth) and wallah got brake lights and horn with no key in it. Had those 2 wires arse about. Thanks a bunch fellas your legends.
73 1200 wagon SOLD
From Armidale N.S.W
Nah your right Nigel, mine needs lookin at was in a rush at the time i reckon i hooked fuse box up wrong as others have said.
Hey tommo can you put this in dummy terms for me ?
you can change the power feed for
them on the back of the fusebox
its on a switched power feed
not a live battery feed
Posted on: 2010/8/1 13:17
Edited by DatsAndy on 2010/8/1 13:45:08
73 1200 wagon SOLD
From Perth WA AUS
Maybe mine is hooked up wrong ( wouldn't supprise me!).
My brake lights and horn work with IGN off, that seems correct to me.
Posted on: 2010/8/1 13:15
