Browsing this Thread:
1 Anonymous Users
Re: Phase 1 - Shed Cleanout (Perth WA) |
From Freo
pm'd Oldskool.. re calliper brackets.. :)
Posted on: 2010/11/13 0:47
'68 Thou Wagon,(home now) up and running '69 2 door project, the yellow thing, A12A Project motor, for the yellow thing. A15 PSI Project Motor '72 CB750k,
From Mandurah, Western Australia
Bump
Will measure corolla diff tomorrow and pont up specs for those who have asked
Posted on: 2010/10/22 12:30
From Freo
how wide are those corrola units???
Posted on: 2010/10/7 14:51
To my knowledge they are the same center.
It has the Corolla drums on it at the moment, although on the other one Im keeping I fitted Stanza Drums and adapted the 1200 handbrake setup. Im sure you could fit 1200 Handbrake setup to it.
You would need to replace the brake shoes, but the drums are OK, and the steel brake lines need replacing
Plus from memory I moved the mounting plates where it sits on the leaf springs, but this is no big deal. Could move and weld these for you.
It still has swaybar mountings on the housing, but can easily cut them off.
Check the WIKI
The diff I.m keeping is a 4.3 but they cone in 3.89 as well
Posted on: 2010/10/7 14:23
From mandurah
awsome ,does it have drums on it ??
oh wait do you know for sure the 120y centre is interchangable with the toyota width housing ??? cos ive got a locked 38.9 ratio centre
the reason i want it is to make the wheels sit further out at the back hehehe
Posted on: 2010/10/7 14:13
77 1200 ute 77mm bore a15 ,12:1 comp ported and reconed h89 head fairly aggro cam ,billet rocker spacers twin 40mm solex carbs on bpro manifold MSD 6al2 with 2 step limiter 4speed 60a box hd clutch 2 inch exhaust locked 4:11 ute diff ...
Jesse, diff is a 4.11 ratio. Prob best to drop round for a look, could pick you up if you like
Posted on: 2010/10/7 12:50
Badge can go towards payment of brake lines. Its yours
Posted on: 2010/9/30 3:07
From mandurah
ill take that rear badge ,and how much for postage to my house ,do you deliver ???
Posted on: 2010/9/29 15:44
bump
Posted on: 2010/9/29 14:51
Re: Phase 1 - Shed Cleanout |
From Secret Harbour WA
pm sent
Posted on: 2010/9/27 14:36
76' B120 GX Style Ute 73' B110 coupe 75' Mini Van 77' Mini Van 71' R100 13B PP i miss it!!! its hiding in my garage in QLD 69' R100 GS Jap Spec 67' Mazda 1500 13b turbo 91' BMW e36 318
