Re: r31 fuel pump on ca18
From Brisbane
You would be pushing the pump very hard at anything above 10psi.
More than that and you should use a Walbro - which is an easy fit into an R31 tank. Also at $170 they're a lot cheaper than a new motor!!
Posted on: 2010/11/2 4:48
From Sydney, Australia
Should be ok, if it happily supplies an RB30.. But not under 20 pound boost with 600+cc injectors.
Posted on: 2010/11/1 11:03
From Brisvegas, oz
has anybody had any problems when using the r31 fuel tank and pump on the ca18det with the standard ca fuel reg had any problems with pressure or flow??
Posted on: 2010/11/1 10:06
www.camerasplus.com.au
