Re: where to get methanol?? vic
Be careful about hobby shop gear. some of it (no idea what brand names or whatver) might have some amount of oil in it (which will stuf up the octane rating a little bit, and defeat the purpose - depending on concentration. So at leat double check if it has any other additives.
Other R/C fuels can contain nitro. I recall some time back someone on the jyturbo list tried it (it was something of a methanol/nitro blend, nowhere near as high in nitromethane concentration as top fuel dragsters run). Now aside from the cooling effect helping density and therefore upping power and also making it safe for higher boost etc. the nitromethane itself should add power too. Anyway he tried it and ran with an already rich 'fuel' mixture, so it was richer than stoich even without the aux methanol/nitro injection and threw it in in quantities around 10-15% of the petrol flow. Anyway - it didn't run any faster like that, or was it safer from detonation or pre-ignition. It seemed to have been finally 'discovered' that it was the oil in this combo that robbed the gains.
Don't get me wrong, there will be trace amts of oil in many racing fuels (often to help prevent efi injectors from sticking etc) but it's the relative amounts that can be an issue.
I haven't tried to purchase it in a while, but people used to go through Shell who sell it (usully in drums) and call it 'shell racing A' - the A standing for alcohol (which methanol is of course - as is ethanol, though thanks to usage it's less common here to call methanol alcohol, and alcohol is normally used to refer colloquially to ethanol.
I think they also had something like 'shell racing m' which was a premix - possibly methanol and castor oil (which is used becaus many 'regular' motor oils won't mix with methanol like they do with petrol, and as such to run methanol on a 2 stroke racer or other engine that needs a pre-mix with oil - they they can't use mineral oils so they use castor.
If you have no luck going through shell you could try:
Coogee Energy supplies - a little bit cut n pasted from their site:
http://www.coogee.com.au/op_meth.html#buying
Coogee Energy supplies methanol in bulk from its road tanker loading facility in Laverton, Victoria and by road tanker or sea tanker from its bulk storage facility in Port Botany, New South Wales.
Methanol is also available in 205 L drums through Coogee’s drum distributors at various locations throughout Australia.
All enquiries for the purchase of methanol should be sent by email to ceadmin@coogeeenergy.com.au or alternatively by telephone on +61 3 9360 2015.
http://www.coogee.com.au/SpecSheets/S ... ee%20BS506%20Methanol.pdf
notes that their's is 99.9% pure - not too bad
If none of those work, you 'might' be able to get it through some paint wholesalers - they might not stock in (they are a potential source of toluene too) but might be able to order it in. Not 100% sure but worth a phone call or two to find out.
If _all_ of them turn up nothing, send me a pm. I have a mate (who I haven't seen for a good few years) that used to run (and almost certainly still does) a turbo lpg centura, and he was undertaking a fairly comprehensive testing plan with methanol injection and various boost and methanol flow rates. I don't remember where he was getting teh methanol from, but I can certainly try and contact him and ask him. The main reason I bring it up ia he lived in Oakleigh (probably still does) which isn't too far away from where you live, so his source would be pretty conveniently located I would imagine.
I haven't looked at any legislation about this, but I suspect that it is far easier to purchase than other 'race' fuel. Since the government has gotten into the ethanol blended fuels 'to save the planet' (even though there's serious drawbacks to its use, it 'sounds good' for a political sound bite and makes them look like they care) - anyway with e85 now being available, it's hardly likely that methanol would be more tightly restricted. Being unleaded etc, it would probably avoid the issues that petrol based race fuels might have. About the only reason it isn't used as a day to day fuel (even on a trial basis) is that it doubles fuel needs fr the same power output, due to stoich ratio etc. Ethanol gets the nod as the increase in fuel consumption isn't nearly as severe.
Posted on: 2010/12/5 10:11
John McKenzie
yeah but that aint gonna make me car fast itll just make me faster than the car atm
Posted on: 2010/12/5 6:22
Car free
head down to stkilda or king street in the city mate...... you will get 'meth' there easy enough lol!!!!!!!!
Posted on: 2010/12/5 2:50
For a cheap car these datos can get super expensive....!
All the bits for my ute have been acquired, I only need time and a panel beater/painter! Anyone able to help
From Whitsunday's NTH QLD OZ
Find someone who makes biodiesel they will have some ,if ya were up this way i could help ya out . cheers
Posted on: 2010/12/5 1:24
still having trouble finding small quantity till I can get some storage for a drum, can anyone help out or want to share some ??
Posted on: 2010/12/5 0:43
Car free
From windsor, sydney
find someone that is involved with the speedway eg sprintcars,midgets ,compacts etc any speedway division should be able to tell you where to get it its about $1.80 per litre if you buy it this way
Posted on: 2010/11/22 22:57
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
From Perth
For smaller quantities of methanold... try hobby shops... they sell by the litre for nitro powered cars,etc
Costs more but means you don't have to buy 44 gallon drums at a time
On the Sunoco website they list these distributors in Vic
VICTORIA
VPW Australia
122-128 Cooper Street
Epping 3076
Phone: (03) 8405 9200
Performance & Race Tech Services
5 Kirkpatrick Drive
Delacombe (Ballarat) 3356
Phone: (03) 5335 8788
Techsport
2/3 Power Rd
Bayswater 3153
Phone: (03) 9720 9300
Vp racing fuels list these
Victoria
Pre Race Engines
4/62 Merola Way, Campbellfield, Vic, 3061
Office Phone: (03) 9357 7668
Office Fax: (03) 9357 7669
Cellar Logistics
288 Lorimer St, Port Melbourne, Vic,
Lee Bektash 0417 857 859
Haddad Race Cars
16A Amberley Crs Dandenong Vic 3175
Office Phone: (03) 9794 6599
Office Fax : (03) 9793 1736
Posted on: 2010/11/22 12:36
ive found that but cant see no meth
Posted on: 2010/11/22 12:10
Car free
From Sydney, Australia
Posted on: 2010/11/22 12:06
hey bige wats vpw??
Posted on: 2010/11/22 12:04
Car free
