1: reducing mechanical power loss from the engine from a mechanical fuel pump
Yeah not sure about that. The power loss would be so minimal it would hardly affect the performance.
If you are considering eradicating the parasitic load of the facet pump in the hope of finding more power then you're better off putting the money for an electric fuel pump toward some bigger valves, better cam or double springs. Removing the mechanical facet pump (which operates on an eccentric lobe) in the hope of finding more power will be an absolute waste of time.
The money for a pump, fittings, lines, wiring, and regulator will be far better off spent elsewhere. These engines are old and they respond particularly well to some smart, straight forward modifications. If you want to get rid of it in favor of finding more power, go find another engine that doesn't have a cam-driven pump.
Weber, Dello and Mikuni all have their PSI rating at around 3, max 6 psi.
If you are running those carbs and you install the electric pump & regulator with the hope to find more power all you are doing is pissing in the wind and wasting your money on an unnecessary upgrade.
If the upgrade is done then and there with the objective to upgrade to an EFI system (but running a
regulated sidedraft carb setup) then I say you are one smart cookie.
I think what Kiri is explaining (sorry I might be wrong?) is a reservoir system that serves as a back-up for when the carbs or induction system are suddenly throttled and require more fuel supply than the normal standard feed, a small tank chockers full of fuel will supply a nice dose of fuel at the required/same pressure as the rest of the system. There are two significant aspects of your fuel system that shouldn't be confused:
1. Pressure.
2. Volume.
You want more pressure for a carb setup, bump up the diaphragm spring.
You want more fuel at the same pressure, look for a bigger pump (be that electric or facet).
