Re: shorter shocks for standard struts
From Sydney, Australia
link to shorter shocks part numbers
Have a look on there, its pretty comprehensive, and there is 2 links up the top to see the other part numbers for other options.
Posted on: 2010/12/10 6:48
B110 sedan
any info on 'how much' shorter the S1 rx7 struts are?
Posted on: 2010/12/10 6:34
John McKenzie
From Christchurch
Ep71 starlet inserts are about the same size as vw golf ones but a little easier to get donw this way (OZ/NZ) they are a little softer dampening though.
Also series 1 rx7 and n10(?) are are little shorter than stock. As well as kp60/61 starlets.
Ep71's are my pick if you want to be real low and they are available in both KYB and Monroes
Posted on: 2010/12/9 2:35
Not too shy to talk
yea ofcourse.
Posted on: 2010/12/7 5:15
From Geelong, Vic
you wont gain any travel unless yo ucut your strut tubes down to suit the shorter shock
Posted on: 2010/12/7 2:46
Not too shy to talk
thanks alot that will help heaps. did u make up the threaded tubes and springs etc ok did u buy them as a kit set thing?
ta dale
Posted on: 2010/12/7 2:07
From Cape Town, South Africa
Look in the wiki for part numbers on shorter shocks: http://datsun1200.com/modules/mediawi ... Strut_Insert_Part_Numbers
I used VW Rabbit shocks, tou can view the build here: http://www.race-tech.co.za/gallery/main.php?g2_itemId=631
Posted on: 2010/12/6 7:19
Project Build: http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=45104&forum=9
Don't find a problem, find a solution!!!!
www.race-tech.co.za
Not too shy to talk
hey im wanting to shorten my struts to give my 1200 more travell when it is lowerd. iv heard its been done b4 and woundering if anyone knows what car i can use the shocks out of that would slide straight into my strut but be abit shorter in length.
if that makes sence to anyone id appreciate your help.
thanks
Posted on: 2010/12/6 4:29
