Re: Rust repairs
From Coondle, WA Australia
by ddiesel on 2011/2/19 3:08:59
Depends on the thickness you are welding.
GENERALLY
0.6mm for datto panel steel which is < 1.0 mm.
0.8 is OK for thicker stuff.
Thinner the material the lower the current and the slower the wire feed.
Use gas for a quality outcome.
READ a lot before starting & PRACTISE lots b4 attacking your datto seriously
http://www.autobodystore.com/new_page_11.shtml
http://www.autobodystore.com/door_rust.shtml
Thanks for the links ddiesel. Some good informaion there.
AS I suspected Ill need to get some 0.6 wire and tips, which is fine. They are consumables anyways.
Now the challanging part. Bending the replacement steel to match factory crease lines and bending. I guess thats just paitence and triming, and hammering, and rolling.....
Its a pity im not at home to post a pic of what Ive got left. The vast majority was done for me by an awsome panel beater, but I can afford to pay him to get it all done. (it seems cheapskates are a common theme amongst datto owners......)
Posted on: 2011/2/18 22:16
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Re: Rust repairs
From Brisbane, Queensland
Yes you need to use a .6 tip otherwise the wire will tend to jump around all over the place and make sure that the wire feed wheels are for .6 also or the wire will slip instea of feeding correctly
Posted on: 2011/2/18 21:27
Until Morale improves the beatings will continue
Re: Rust repairs
GENERALLY
Posted on: 2011/2/18 19:08
Re: Rust repairs
From Secret Harbour WA
pretty sure you can i use .8 most of the time but i reckon .6 would be better as it wouldn't put so much heat in the thin metal that it will bend or buckle when cooling down....
Posted on: 2011/2/18 12:31
Re: Rust repairs
From Perth WA AUS
Can you get 0.6mm flux core wire?
I might try that, makes sense. Will I have to change the Tip (currently 1.0mm)?
Posted on: 2011/2/18 12:16
Datsun 1200 2Dr sedan.
Re: Rust repairs
Use .6 wire
Posted on: 2011/2/18 11:44
Re: Rust repairs
From Perth WA AUS
Yeah that makes sense, with my car the rust just kept going!
So I started cutting it out first then making replacement sections and I'm still going :(
Posted on: 2011/2/18 11:35
Re: Rust repairs
The way that fazpioes said means that the replacement part is a perfect fit to the panel as opposed to cutting a hole first and trying to cut a replacement of the right shape and size.
I think it works for some situations. I guess you could cut a shape using the rusty part you've cut out......each to their own?
Posted on: 2011/2/18 10:44
Re: Rust repairs
From Perth WA AUS
I thought it was the other way round?
Posted on: 2011/2/18 10:39
Re: Rust repairs
From PORTUGAL
Hi reuby_tuesday
One mistake people do is 1st to CUT Rusty Part
- FIRST - DO THE NEW METAL PART
- SECOND - MARK IT OVER THE RUSTY PART
- THIRD - CUT IT OUT
- FORTH - WELD IT
Posted on: 2011/2/18 10:24
The Worst it Looks - Bigger The Challenge ...
