Re: How to test a clock...
From Seattle ,WA.
Got it working, yeah! now lets hope it'll run for a few days solid, we'll see....
Posted on: 2011/2/22 2:48
From Seattle ,WA.
when you say 3rd wire I assume you mean the blue one? I am missing the 2 lightbulb wires.
If it doesn't work has anyone had any luck repairing one?
Posted on: 2011/2/21 18:37
The 1200 clock has a third wire, which goes to the Red/Black wire hanging down from the harness. This is the constant-Hot wire. If you wire to IGN, it only runs when the key is on
See Wiring
Posted on: 2011/2/20 4:11
From Coondle, WA Australia
Most car clocks will also have a third wire, that is used to dim the light when the healights are on if its digital, or to turn on a light if its analog.
You may or may not need to have iot hooked up. Its usually also a 12v feed, so you can just twitch it to the positive for the clock unit.
But yeah, one to earth the other to 12v positive (assuming its a 12v unit.)
Posted on: 2011/2/20 2:46
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Seattle ,WA.
Is there anything special about testing a clock or is it just a straight 12V connection to the leads - one ground & one positive?
I picked up a clock & want to see if its working.
Thx.
Evan
Posted on: 2011/2/20 1:45
