Re: Superchager blow off or safety valve setup
if you can get propane at a good price great!
I have a place that sells it near by but most
places sell it mixed with inferior octane gases.
Posted on: 2011/3/28 4:47
From Snohomish, WA USA
LPG? Propane?
Posted on: 2011/3/28 3:41
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
10 gallons is like 37 litres so not too bad for a day of aggression.
Can you get LPG your way?
Posted on: 2011/3/28 2:33
Good! You don't need an Afterburner? Speaking of burning, I've gone through 10 gallons of fuel today. This car sucks the tank dry, but it pulls hard!
Left GG early. Drove through and the place was packed. Didn't park the car but it took me over a half an hour to drive through it and see all the cars. Not one 1200 on the lot. DD was suppose to be there but I didn't see him. Just spent the rest of the day racing around the country side.
Posted on: 2011/3/28 0:51
'73 2 Door Sedan
I was thinking of having no blow off valve just the spring thingy setup
in case of backfires which are rare by detrimental to the SC.
If go for a BOV I would plumb them out somehow if possible using some
tubing to either the wheel wells, below the road, gearbox tunnel non
exhaust side or windscreen to clean the bugs off :)
Posted on: 2011/3/28 0:27
That setup looks tight!
Is that diagram a blow through or draw through? Looks like a draw through. Are you still considering using a blowoff on a draw through? A draw through blowoff valve will blow fuel all over your engine compartment.
Posted on: 2011/3/27 17:13
Edited by datsa73 on 2011/3/27 20:35:21
'73 2 Door Sedan
This is the layout viewed from the front (radiator cap height)
It will make a clean setup with support from the engine mount
and further support from the back of the head with another bracket
not pictured but double side engine mount supports might be enough.
jpg  superchargedAseries.jpg (85.04 KB)
737_4d8f1569436e7.jpg 1078X623 px
Posted on: 2011/3/27 11:47
Yes I will still SC the A10. I have most parts coming together.
Chris can you post a pic of your eaton m45? is it like a mini one?
I found that model also hard lay out properly without to many plumbing
but it all depends on which model you have.
This is my decision
http://datsun1200.com/modules/newbb/v ... id=361379#forumpost361379
As it will allow the su to face the left hand guard and still allow a filter
without touching it but no longer will i run the kangaroo water bag.
Crank and Alternator will run twin pulleys and rear of alternator the same or
4 row ribbed belt to the supercharger pulley. So no piping at all.
Posted on: 2011/3/27 11:16
Sounds good,just need to machine some decent platforms up to make sure the valve doesn't walk and leave it's seat. I'm sure any machine shop could machine the opposite face of the valve, but whether you need a synthetic seal or not I'm not sure. I liked the idea of the rubber platform with the springs, would me easier to do I think.
Are you still supercharging your A10? I have a new Eaton M45 and factory EFI A14 coming together, bit of a plumbing nightmare at the moment. Just need to sell my old engine to free up some dosh (very hard to part with ).
Posted on: 2011/3/27 11:03
Yes the double valve spring would be too much and although modern BOVs are avail
I just love the look of this setup along with the rest of it period finishings.
Im thinking of a similar setup using a long diesel truck inlet valve positioned
so the spring and retainer are on one side of the plenum in the open and a seat
like finish for the valve on the other side of the plenum. That way if theres a
backfire the valve will just pop open. As long as the spring can keep pressures
under 20psi as Ill be running 10psi it should be fine?
Posted on: 2011/3/27 10:57
