Re: whats the best way 2 remove 120y struts etc
Supercheap
Although the Big Hammer method (with or without pry bar) always works too, if you swing it hard enough and enough times ...
Posted on: 2011/4/25 9:37
From Innisfail nth queensland
thanx fellas thats all the advise i need get on2 it in the morning
Posted on: 2011/4/25 9:23
help me iv got a 1200 ute after sum1 in north queensland with datsun parts
From Ringwood, Melbourne, AUS
Oh yeah, try not to damage anything else while wielding the FBH!
Posted on: 2011/4/25 9:14
Deano
To remove tie rod ends you use a hammer.
Remove the nut & cotter pin.
* Use a pickle fork and hammer
or
* Use a rod-end puller
or
* Use prybar and hammer on the knuckle
never hammer on the tie rod itself
Loosen the castle nut that holds the tierod end to the strut steering arm so that it still covers the end of the tierod thread (or if you don't care about the tierod end then take the nut right off).
Now get a FBH (f-ing big hammer) and belt the steering arm on the end so you hit it at 90 degrees to the tierod end that passes through the arm. Keep hitting it really hard until the tierod pops free from the steering arm.
Posted on: 2011/4/25 9:13
Deano
how do i undo them with ease got 1 side off but had 2 litrealy hold the whole strut assembly and unscrew it took ages
Posted on: 2011/4/25 9:10
tie rod ends
Posted on: 2011/4/25 9:07
Re: whats the best way 2 remove 120y syruts ecc
three nuts on strut tops, balljoint and tierod at the bottom and then just the brakes, either undo hose at pipe or caliper end.
What are you having issues with?
Posted on: 2011/4/25 9:05
Deano
whats the best way 2 remove them having some trouble? Do i need any other steering parts off the 120y
Posted on: 2011/4/25 9:01
