Re: E O I - A series underdrive crank pulleys, Aust.
Only way to machine that pattern would be with a mill and a dividing head/rotary table/CNC which is either time consuming or expensive.
The CNC once setup would do 10 pulleys in 2 hours (would include setup, programing etc) and at $120 an hour thats and expensive "timing" stator.
Posted on: 2011/5/11 11:33
ssskiwi wrote:
I am interested..
What about machining a common tooth pattern into it for firing a crank sensor? I.e. something like the 36-1 that is needed for running a MegaJolt ignition controller?
If not needed it is simply not used but otherwise makes the pulley a hell of a lot more useful!
Just a thought..
would be real interested if you could machine a tooth pattern into it for a crank angle sensor like sss suggests, or at least be able to bolt it to the underdrive pulley??
Posted on: 2011/5/11 11:10
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
I'd be interested but the price is much too high (for my budget).
Is there an option for an aluminium version? I'd be keen on one of those I reckon.
Posted on: 2011/5/11 10:39
Quite a regular
Underdrive
Think of it this way, underdrive means to slow down. Underdrive crank pulleys are designed to slow down engine accessories and reduce parasitic loss.
Crank pulleys, attached to the outside of the crankshaft, are the source of power for a car's accessories. The alternator and water pump are belt driven units, attached to the crank pulley, that use horsepower from an engine to provide their own services. This draw of power by these accessories is called parasitic loss. Underdrive crank pulleys increase an engine's throttle response and horsepower by reducing the power required to drive these external accessories. By replacing factory pulleys with smaller diameter units, the accessories are slowed enough so that their performance does not suffer, but just enough so that more horsepower is sent to the wheels and put to the ground and also benefit from increased accessory life and also deliver better fuel economy.
Posted on: 2011/5/11 8:09
From Ringwood, Melbourne, AUS
I am interested..
Just a thought..
Posted on: 2011/5/10 9:35
Deano
From Rosewood, QLD
does look sexy
Posted on: 2011/5/10 9:16
1971 B110 sedan project.
2012 Nissan Micra daily.
From Brisbane
Deleted my stuff so as not to be confused with what beaufort is offering - sorry mate.
Posted on: 2011/5/10 8:39
Edited by Lemonhead on 2011/5/10 10:41:18
Edited by Lemonhead on 2011/5/10 10:41:46
From Rosewood, QLD
ahh cheers Chris and Benny i had it all backwards, long day at work.
Posted on: 2011/5/10 8:38
From Sydney
ZigZag wrote:
wouldnt water cavitation be worse with one of these cause they will be spinning even faster?
please forgive my ignorance and educate me.
with an underdrive crank pulley, the alternator and water pump will spin at a lower RPM in relation to the engine rpm. Worth noting that the alternator will start producing charge at a higher engine RPM as a result. e.g std charge starts at ~ 1500 engine rpm, when being driven via a undersize crank pulley, the charging will occur around the 2000 rpm there abouts. Ideally underdrive pulleys are suited to high RPM engines when you want your alternator and water pump to operate at more realistic speeds.
Posted on: 2011/5/10 8:34
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
The smaller the drive pulley the lesser the rotation of the subsequent pulleys.
If the pulley were over-sized you would speed things up.
Posted on: 2011/5/10 8:32
