Re: Diff /axle help....
From windsor, sydney
that just looks like a major cluster f#$* they got the housing wrong and had to come up with this as a solution to the problem , where is the seal ? is there a O ring in that steel spacer behind the bearing?
Posted on: 2011/5/31 23:27
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
hey guys,
getting a new housing soon, pulled the axles out this arvo. got me f&^#ed whats going on. the end of the diff housing has a lip and that spacer piece has a grove that mathes the lip, the spacer also has been pressed onto what looks to be a bush behind the bearing.
maybe the pics might help
than i found this pic on the net which makes me think is it a standard thing??
Posted on: 2011/5/30 14:05
thanks guys aprrecitate the advice, housings in the bin!!!
Posted on: 2011/5/27 13:41
From Geelong, Vic
the thing i like most about it is that you can visiby see the change in angle of the axle tube where they cut it. Bin the housing and start over
if its LSD, judging by the workmanship of the diff, they might have just not had teh 2 splines in the LSD lined up, and therefore the axle wouldnt go in all the way. so they thought that spacing it out might be the better option
A mate did the same thing but cut the end off his axle to get it in....only to be told shortly after that you need to make sure the splines are lined up first
but if you pull it apart, make sure the splines are lined up, then put both axles in the lsd (all outside of the housing) you should be able to get an idea of the length it will be
Posted on: 2011/5/27 2:50
I cant believe the s**t that some people make and expect to work.Anyway what is the solution? If the overall width of the diff is what you want that means the axle lengths may be acceptable (pending where the pinion position is) then all you have to do is a new housing to suit the axles .Iwould only use new bilett bearing ends and thicker retainer plates, what is the deal with the welded on caliper mounts, dosn't it have handbrakes?,best of going back to the standard commodore backing plate if you can fit them between the springs , it can be a relativly simple conversion if you keep it simple and use the standard parts .Brian
Posted on: 2011/5/27 0:13
WARDMAN ENGINEERING
CNC machining
0413 595 627
mine did that once i pulled the axles out, the axles just weren't going back in the whole way. I def wouldnt be drivin a car with a diff that looks like that! But yeah as said above, pull it apart ad sus out what has been done.
Posted on: 2011/5/26 19:12
thanks mate, hope the axles aren't to long,could use that extra 15mm each side!.
Posted on: 2011/5/26 14:20
From Gold Coast
Yeh by the sounds of that they have stuffed up along the line then just made it work.. Rip her apart and have a squiz
Posted on: 2011/5/26 13:48
hey wards, that extra piece looks to be a smaller od then the diff and has silastic on both ends.
i might pull it apart and see WTF they've done. just thought id check if its a standar thing.
Posted on: 2011/5/26 13:31
From Gold Coast
Looks to me there is a bit added in there, as though it was too short and had a bit added... Odd
Posted on: 2011/5/26 13:26
