Re: Sunny ball joints into 1200 struts??
The ball joint is connected to the steering knuckle. The knuckle is connected to the strut.
Posted on: 2011/6/18 5:27
From Geelong, Vic
the balljoint doesnt actually go into the strut to begin with. the sunny balljoint will go into late 1200 ute steering arms (the bit that bolts to the bottom of the strut) and will bolt to the control arm and will give an 8-10mm track increase either side of the car
Will not work with early 1200 steering arms or control arms
Posted on: 2011/6/18 4:48
I think they will not fit.
Posted on: 2011/6/17 21:23
Hi.Does any one know if sunny ball joints go into 1200 struts?? Cheers
Posted on: 2011/6/17 6:55
