Re: wanted door lock mechanism 1200 ute
Not too shy to talk
From Sydney, Australia
I now know that the locking mechanisms are different for utes and coupes, as the doors are a different size, the mechanism is larger in the coupe to suit the door.
Fortunately a locksmith could fix the stuffed one.
Posted on: 2011/11/19 3:17
Not too shy to talk
Does anybody know whether or not the locking mechanisms are the same in all 1200s?
Am I correct that the doors are different for 4dr sedans, coupes and utes? I'm going to try and source a new mechanism but I need to know whether ute mechanisms will work in a coupe?
Posted on: 2011/11/14 21:41
Mine wouldnt lock for the longest time until I loosened the plastic nut on the rod off the outer door handle inside the door. Try that and see.
Posted on: 2011/11/12 13:02
Not too shy to talk
I know this thread is old but does anyone know where to get the door locking mechanism?
Mine has shat itself in the coupe and the passenger door won't lock without it.
Posted on: 2011/11/12 7:12
From Melbourne, Australia
I bought the set from the Aussie guy in Sydney that are "keyed alike" so you have one key for door lock, ignition and I'll modify the boot lock barrel for the fuel door.
A petty thing I know but it s#$ts me to have to fumble around for the right key!
$125 is pretty good value I reckon. You can also then get the modern style Nissan keys cut to suit like this-
Posted on: 2011/7/13 23:13
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
As long as drivers one works it's perfect for a daily.
EBay has sets but I can't justify $100 a pair
Posted on: 2011/7/13 20:36
Which part do you need?
Inside lock, outside lock, latch or striker?
The B120 diagram here is almost identical to the Coupe, except that the insulator (80504F) is not used except on newer B120. The part numbers are mostly the same as Coupe, except for the latch and striker.
Posted on: 2011/7/13 20:09
hey guys i am looking for the door lock mechanism for my 1200 ute on the passenger side door i am in desperate need as its my daily please let me know im in sydney area pm me if any info
Posted on: 2011/7/13 10:56
