Re: 180B strut shortening for 1200 ute.
trying to get the wheel under the guard using camber won't work real well it's way to far out. my wheels sat out of the guard about the same and i had a huge amount of camber looks like im getting ready to go out on the track lol
Posted on: 2011/8/12 8:40
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
From Geelong, Vic
The wheel sits 20mm inside or outside the guard with a 6 inch wide wheel with a +25 offset???
on my car with 200b struts, lengthened control arms and 15x6 +20 offset wheels the wheel is still inside the guard.
But it sounds like you are trying to get the wheels in further if you are wanting to machine the wheel mounting down
But then wanting to lengthen the control arms to get more -camber, which would push the wheel out further
What size wheels and tyres are you running? 205/40 something it sounds like which on up to 15s or 16s shouldnt really be a problem
Using adjustable castor rods, it will pull the balljoint as far forward as you adjust the rod, or a little further coz its located further out on the control arms
too much camber, for the road more than a couple of degrees will probably see you going through tyres rather quick and not actually going round corners as well at normal street driving speeds due to the tyre contacting the road
Castor, dont think you will really be able to get too much, you will just have to cut your actual guard out so that the tyre doesnt catch it, and your steering will be heavier and have less lock the more caster you go
Posted on: 2011/8/12 3:52
ive installed the struts and camber tops left the coil over sleeve floating for now,
need some help with castor and camber guide lines.
ive gained about 15mm neg camber by shortening the struts and camber plates, and the wheels still sits past the gaurd 20mm.
im going to purchase some adjustable LCA's to gain a bit more -camber. is 20mm asking to much? the wheels are a 25 offset and the way the wheel is designed the spoke already petrude the outer rim so going for more offset really isnt an option as yet. i can machine the back of the wheel 5-8mm as there about 12mm to the spring and heaps of room for the caliper. also could go a 185 instead of the 205 on a 6" rim? which would allow me to machine more off the wheel hub? how much is too much -camber?
as for castor, using adjusable rods how much does in actually pull the B/J foward? at the moment the tyre hits the inner wheel well when it not even half turned so im guessing ill need about 15-20mm? i can also go a 35 profile tyre instead of the 40. and get a smaller rolling diameter? how much is too much + castor?
any help appriciated guys.
Posted on: 2011/8/12 1:43
From Melbourne, Australia
Hey Rob, glad to hear you got all your bits together!
You do need to cut out pretty much exactly the amount that the insert is shorter. The only thing you need to be careful of is that the cap seats on the insert the same way. As in if the flat of the cap touches on the same part on top of the insert. The Stanza cap has a ring inside that holds down the insert. With the R31 inserts being bigger in diameter don't touch the ring so it makes it seats a bit different. I think the 180 strut caps are flat so shouldn't be a problem. Just put your tape measure down the tube with the insert in to make sure of your measurements.
My struts are cut up ready to be welded hopefully tomorrow. I'll take some pictures of that and the inserts and how they go into the strut tops.
Posted on: 2011/8/6 1:59
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
thanks for all that advice guys,
went with shoota's advice and got the KYB camry insert perfect dia fit with a 332 body lenght.
Just wanted to confirm im doin this right and maybe it might help some guys in the future.
Body lenght of the new insert is 106mm shorter then the original insert, is that how much i remove from the strut tube?
(hopefully these bodgy paint pics help!lol)
Im using HSD sleeve kit and going to order a set of ebay camber plates so it might be self explanatory when i get em but ill ask anyways.
where on the insert shaft does the top spring perch sit? in the 15mm section? or on the notched section? (marked X) or??
These are the camber tops im thinking of getting they have an 18mm interal dia hole in the berain will i need different shims?
Posted on: 2011/8/5 14:29
Bursons sell KYB's for about $140 each retail. They might be worth considering. Anyone got any feedbac about KYB's??
Posted on: 2011/7/30 2:26
Current Fleet-
From Geelong, Vic
Only problem with the camry inserts is that you cant find good quality ones easily, not that i've found anyway. I'm stuck with dodgy pedders ones that I'm not sure really do much
Think you can get konis that are pretty short. alot more expensive but probably worth it in the long run
Posted on: 2011/7/29 13:20
With you having the four link and being able to go super low I would go with the Camry inserts as they're another 1.5 inches lower. Just make sure they're the right year as there is a short and long version. I'll check the list and post up the year range when I get in to work.
Edit- It's the 87-92 Toyota Camry or Holden Apollo that has the 332mm inserts in it.
Posted on: 2011/7/28 21:35
Edited by Shoota_77 on 2011/7/29 0:09:37
Current Fleet-
appreciate all the advice guys, cleared it up for me.
gonna tackle it next week!
r31 inserts are the better option?
Posted on: 2011/7/28 13:18
From gold coast QLD.
I also always use a couple of quality hose clamps to sit the sleeve on,and also set the spring at the centre point of the sleeve.
Posted on: 2011/7/28 6:08
