Browsing this Thread:
1 Anonymous Users
Re: Whats difference between B122 n B310 frt brake system |
From Malaysia
Sorry, i mean B122 vs B310 brake set....
Posted on: 2011/8/6 11:45
B110 1972 Modded A15
Re: Whats difference between B122 n B110 frt brake system |
From Malaysia
Thanks DD for replying... I mean if comparing late b122 brake set as the pic vs those stock b310 brake set(i forget that im using b310 strut n brake previously)....
Posted on: 2011/8/6 11:42
Registered Users Contentmaster Usermaster
Early B122 uses drum brakes, but later B122 uses those disk brakes in the photo.
It is not superior as B110 has a twin-piston caliper and larger rotor, while B122 has single-piston and smaller rotor. Both fit under 12" wheels.
Posted on: 2011/8/6 6:49
From Malaysia
Hi,i recently install this B122 brake set to my sedan B110. It looks different compare to my stock b310 brake set as the pads are wider. It loos the same as this pic i copy from DD.
Does the B122 UTE brake system more superior than B310? Thanks
B122 UTE brakes.jpg (28.74 KB)
Posted on: 2011/8/6 5:44
Edited by ronald_loulan on 2011/8/6 11:43:35
