Re: Fly wheel bolts torque setting
From brissie
Champions thanks guys. Anyone know where I can get a pic of the dismantled view of the throw out bearing folk housing spring
Posted on: 2011/9/10 3:53
A12,4spd, mild cam ,head work, mags.
64lbs for the old tools :)
Posted on: 2011/9/10 3:00
From SE Melbourne
More info if your interested....
TORQUE WRENCH SETTINGS
Cylinder head bolts . . . . . . . . . . . . . . . . . . . . . . . . . 74 Nm
Connecting rod nuts . . . . . . . . . . . . . . . . . . . . . . . . 37 Nm
Flywheel bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 88 Nm
Main bearing cap bolts . . . . . . . . . . . . . . . . . . . . . . 59 Nm
Camshaft sprocket ......................... 47 Nm
Camshaft locating plate . . . . . . . . . . . . . . . . . . . . . . 8 Nm
Sump bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Nm
Oil strainer bolts . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Nm
Crankshaft pulley bolt . . . . . . . . . . . . . . . . . . . . . 196 Nm
Timing chain cover bolts . . . . . . . . . . . . . . . . . . . . . 7 Nm
Rocker pedestal bolts . . . . . . . . . . . . . . . . . . . . . . . 25 Nm
Valve rocker adjusting nut . . . . . . . . . . . . . . . . . . . 22 Nm
Sumpplug . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 29 Nm
Posted on: 2011/9/10 2:40
Mildman, Datsunless
From SE Melbourne
88Nm for A14/15 - I assume same for A12
Posted on: 2011/9/10 2:37
Mildman, Datsunless
From brissie
Can anyone tell me what's the torque settings for fly wheel bolts ??? Cheers.
Posted on: 2011/9/10 2:25
