Re: B110 Early/Late Steering Questions
Ask scott. He can answer most things that come up when he sells things.
Posted on: 2011/9/20 13:35
For a cheap car these datos can get super expensive....!
All the bits for my ute have been acquired, I only need time and a panel beater/painter! Anyone able to help
Not sure but I'm using stock drag link and stanza inner tie rods fit that, using stanza outer too but I'm not sure on steering arms, they must be late model ones. Get late model stuff do you can use stanza ball joints for extra neg camber if you want it though
Posted on: 2011/9/20 10:21
From Sydney, Australia
Not worried about engineering dude, just want them for adjust-ability.
Just need to know what will fit what so that I can start ordering parts.
Posted on: 2011/9/20 10:15
B110 sedan
Adjustable LCAs are a definite defect on NSW roads.
I don't think you can get them xrayed and engineer approved either.
They will say 'offroad use only' on the packaging.
as for steering bits.. I can't help sorry. I'm old school only.
Posted on: 2011/9/20 10:10
Ok so my b110 sedan is 1971 and so it runs early model steering gear/ front end.
All the joints are shagged to say the least and so I'm looking to replace the lot.
I want to run the maddat adjustable LCA's and caster rods(late), so I will then have to run a late ball joint, and now comes the part i need to know.
Will the late ball joint fit my early knuckle? So then i can just replace my current steering parts with new early parts.
Or if not, i could find late knuckles and will it, fit the early tie-rod ends?
And if thats not possible, will late steering parts fit my car and bolt up to my early pitman arm/idler arm.
Posted on: 2011/9/20 9:54
B110 sedan
