Re: F/S Datsun 1200 120Y B110 B210 Alloy Bump Steer Spacers
Bump - I have one set left, and thats it, won't be getting anymore
Posted on: 2011/10/13 18:42
Generally from what I understand.
Although I sold a set to an old guy over here in NZ, who has not got real low suspension, but gets a lot of "bump steer" when he drives on the open road, he has dialed in some more castor, and wants to fit these spacers, to hopefully get the front end to behave itself a bit more at open road speeds.
Posted on: 2011/10/11 19:04
Cool thanks for the info. So you only want to install these when you lower the suspension?
Posted on: 2011/10/11 11:04
not a very good photo but you get the idea
jpg  bump assy small.JPG (29.85 KB)
9374_4e940b47863a8.jpg 448X336 px
Posted on: 2011/10/11 10:24
From Sydney, Australia
Under the strut, above the ball joint. Corrects the angle of the LCA when you lower the car.
Posted on: 2011/10/11 9:12
B110 sedan
Just curious... Where do you install these?
Posted on: 2011/10/11 8:58
From Sydney
PM sent.
Posted on: 2011/10/11 0:36
BUMP STEER SPACERS / ROLL CENTRE ADJUSTERS
Improve handling over uneven surfaces due to changes in suspension geometry / height of spindle, shock etc.
Keep the Geometry correct so your lower control arms arent above the horizontal!
These also look flash as too!
Details:
75mm Bolt centres (Suit all 1200's and 120Y's)
25mm thick
6061 Grade Aluminium construction
CNC Machined (and I had them red Anodized as well)
Included (12.9) high grade ZP cap screws with washers and nuts
Nice Quality, bolt straight in (although I had one strut bottom with a slightly daggy weld, that I had to give a quick lick with the dye grinder)
Datsun Nissan 1200 120Y B110 B210
2 sets available - PM me or email me first in first served.
AU$150 delivered
jpg  bumps small.JPG (21.11 KB)
9374_4e93311809293.jpg 448X336 px
Posted on: 2011/10/10 18:56
