Re: Steering Options for 1000
Not too shy to talk
From Melbourne Australi
D wrote:
Are you allowed to change carburetion and exhaust?
Yes, I've got twin 40mm weber side draughts and "extractors" (whatever the technical term is).
I have to use the original block and head. They can be modified by removal of metal but not addition. Internals are free thus the possible crankshaft change.
Mark
Posted on: 2011/11/1 9:17
Mark Laidlay,
Melbourne Australia
1967 B10 Historic Rally Car
J13 and there is a E1. However I saw a E1 at a wreckers
a year ago and told someone at crankshaft rebuilders
then as he had a friend with rallye 1000 a10 supposedly
and was looking for a stroker crank.
It surprised me to see such an engine and its listed here
http://en.wikipedia.org/wiki/Nissan_E_engine
with 71mm stroke and 76mm bores youd get 1288cc !!!!
enough to frighten many cars in that light body.
Posted on: 2011/11/1 7:35
Not too shy to talk
I am allowed to use an A12 crank, not block. But being five bearing it's out really.
I left the word "crankshaft" out last time sorry.
Mark
Posted on: 2011/11/1 3:16
Mark Laidlay,
Melbourne Australia
I was under impression you cant use an A12?
Also not allowed steering rack?
Posted on: 2011/11/1 1:39
Not too shy to talk
D wrote:
whats the engine in your rallye 1000? A10?
Some bloke was saying long ago that a J13
crank is a possible upgrade for stroking.
Motor is A10 bored .5mm. Stroking is legal but A12 being 5 bearing is not really sensible. Now where do I find a J13 to get a crank?
Thanks, more cost. Mark
Posted on: 2011/10/31 22:27
Mark Laidlay,
Melbourne Australia
Not too shy to talk
This steering quickener concept has me thinking, I now have several 3 and 4 speed gearboxes doing nothing (including a 56 option 1 4 speed). I could put one of those in the steering column, just cut down the bellhousing etc, Then I can change ratios to suit conditions and the strength in my arms. I think the steering box would would need to be at the input end.
I wouldn't have a clutch or permanently mounted gear lever, changing ratio on the move would be just silly!
Mark
Posted on: 2011/10/31 22:25
Mark Laidlay,
Melbourne Australia
Posted on: 2011/10/31 13:22
Not too shy to talk
It's about 3.5 turns lock to lock. 2 to 2.5 would be better so I can react quicker on loose surfaces.
Mark
Posted on: 2011/10/31 11:27
Mark Laidlay,
Melbourne Australia
From Perth
1000's are a gokart
Can't understand needing the steering quicker
Maybe start playing with ratios in the box (having them made) or custom arms
But don't go introducing bump steer and other issues that make the car unpredictable
Posted on: 2011/10/31 11:06
Not too shy to talk
I've never heard of a steering quickener before but will investigate. There's even one for sale on ebay!
Thanks, Mark
Posted on: 2011/10/31 11:05
Mark Laidlay,
Melbourne Australia
