Re: ca18 over revving problem
Glad to hear about the outcome. The less common causes are usually the hardest to figure out.
Posted on: 2011/11/30 0:48
From Brisbane
Problem was partially severed throttle cable which was catching and causing the butterfly to stay open, but didn't show up when I checked the butterfly!
How annoying.
Posted on: 2011/11/30 0:23
From Sydney, Australia
Sounds like intake piping is wrong, or aac valve is stuck open. first make sure that the only hose that bypasses the throttlebody is the one that feeds the pipe that goes to the AAC Idle control block.
Posted on: 2011/11/23 9:37
From Brisbane
Engine is a DET. Yes I did pull the intercooler hose off to check the throttle was closing.
Must be a leak somewhere else. I remember it happened while I was coming out of a corner on boost.
Would be a huge leak though as it reaches redline in 2 seconds.
Posted on: 2011/11/23 8:02
From Melbourne, Australia
have you pulled the air hose of the front of the inlet to check the throttle is closing
iff the idle screw is set with idle too high and there is no load on motor then yeah it will just rev up,
got to be throttle not shut
Posted on: 2011/11/21 9:06
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Near Bundaberg QLD
Is it a DET or just a DE?
Posted on: 2011/11/21 8:58
Thanks, Sam-U-El/Racer135
4 utes, 1.5 sedans, 2 120Y sedans, 1 C120, 1 1600 sedan, all look like or are wrecks
ECU cannot cause the engine to rev over redline -- so why are you replacing it? The ECU can only limit the redline -- it can't exceed it.
If your throttles are actually closed, air is getting to the engine elsewhere.
Posted on: 2011/11/21 6:50
From Brisbane
It is an aftermarket ecu, so I'll replace that. My feeling was that it would be an air rather than fuel leak, so perhaps the intake manifold gasket has blown a hole or as you say the IAC is stuck.
Thanks
Posted on: 2011/11/21 5:13
Heard of electrical issues with aftermarket installs where they remove rev limiter and as older ecu had no cold start some have issues due to faulty sensors
Posted on: 2011/11/19 3:16
You must have a massive air leak. It doesn't matter about the ECU -- the ECU can't supply air to the engine.
Maybe the IAC is stuck open or something.
Posted on: 2011/11/19 2:46
