Re: engine temp raising
From Malaysia
perhaps the 'clutch' on the fan isn't grip enough? i've seen 1 or 2 cases like these, the fan is too slow when idle. replace the silicone fluid inside the clutch, problem solved.
Posted on: 2012/2/5 4:42
From Ringwood, Melbourne, AUS
Also make sure that the waterpump is OK, as they get older and especially if they have been run without proper anti-corrosive coolant, the blades on the impeller can corrode. Also, the surface on the timing cover that the impeller runs against should also be smooth, otherwise it will cavitate and/or not flow well.
Posted on: 2012/2/5 2:01
Deano
Not too shy to talk
fanx guys :)
Posted on: 2012/2/5 1:21
Yes, if you fit a larger/triple core the temp will be more steady.
But varying a little is normal and won't hurt the engine. I've had a 1200 since 1981 and never blown a head gasket. Temperature moves a bit in the normal range. Cools down at idle, raises a little on the highway. As long as it doesn't cross the H mark, it is OK.
I run A12, A14 and A15 with the stock 1200 radiator. No problems.
Getting hotter at idle is a fan problem. Electric fans often don't work as good as the stock engine-driven fan.
Posted on: 2012/1/26 23:46
From Seattle ,WA.
in a newly rebuilt A15 engine with a new 3 core radiator running an electric fan & a re-cored heater core & new control valve my temp gauge is always at the middle of the gauge or slightly under it. Laser temp says its 178 - 180ish F water temp.
you can see the gauge a little.....
Likely its not just airflow, if any of the cooling system components are original or have a lot of age to them it can be all factors. Blocks, radiators, heater cores & valves clog & reduce flow - most likely candidate is the radiator water flow .
Getting hotter at idle should be more common as theres no airflow over the rad as well as less coolant circulation thru the motor.
Posted on: 2012/1/26 17:53
Not too shy to talk
yea the engine temp is at the picture u uploaded, i was just worried that it was too high. thanx alot guys
Posted on: 2012/1/26 13:33
Getting hotter at idle is not so common, is it? The ones I've seen get hotter at speed.
Sounds like not enough air is flowing at idle.
* If you have the wrong A12 fan, it may be too far away from the radiator (normal is about 1" (30 mm).
* Shrouding can be important depending on the radiator and core support (some have a gap and need the shroud, others don't need the shroud).
Posted on: 2011/12/5 23:00
It's probably just airflow or partial blockage in rad. I've learnt how important shrouding is too.
How hot is it getting in traffic?
Posted on: 2011/12/5 21:50
According to Owner's Manual: Water Temperature Gauge, this is the normal range:
Posted on: 2011/12/5 20:18
Not too shy to talk
nah it rises when im stopped. and i use the factory fan
Posted on: 2011/12/5 13:46
