Re: Wtb a series 5 speed
They are different boxes. 60L is a dogleg, 60A is straight pattern.
Both are overdrive. Gear ratios are slightly different but nearly the same.
See 5-speed Overview
Posted on: 2012/1/31 21:21
Edited by ddgonzal on 2012/1/31 21:47:09
I was under the impression that 60A and 60L were some ratios.
but someone on here will know for sure.
spinning shaft it felt like 1:1 5th, but probably need to mark splines and spin a few times, cause if its over driven will only be like 1.03 or something?
Posted on: 2012/1/31 18:08
Quite a regular
"Standard shift pattern"... Does that mean it is an overdrive box ?
I have a dog leg 5 speed ( 1st is back and left )
Are they the same box ?
Cheers
Posted on: 2012/1/31 14:09
Oh, didnt realise - thanks for that, better see if I can find a 60 series one lying around, to might it easier for prospective buyers.
Posted on: 2012/1/31 5:23
Probably worth pointing out that the 60 series clutch release lever is different from the 56 series. This has been the source of much confusion.
Posted on: 2012/1/31 3:00
Got the box out.
its a 60A (standard shift pattern)
selects nice and tight
out of sunny coupe only done 126km (or miles?)
no shifter assembly, no throw out bearing/lever.
Clean example, been in storage just over a year, but out of running car
(although I havent driven car as brought by itself)
Some minor surface rust on input shaft, but nothing major.
Good to go, just top up the oil and fire your shifter & throw out arm off your 4 speed at it.
delivery 3-5 working days ex: NZ
Posted on: 2012/1/31 0:05
Hi guys, decided to sell my other spare 5 speed, need to further fund my coupe project.
Removed from running car (1980 Sunny coupe) and put into dry storage.
will try and get it out at the weekend and take some pic's.
cant remember if its a 60L or 60A , will check when I get it out from storage (hopefully over the weekend)
Located in NZ, but will do for AU$750 delivered to your door.
First in first served
Posted on: 2012/1/26 23:34
Quote: due to miss packaging. Who is this Miss Packaging....she sounds like trouble. [end dad joke]
Must be mrs palmers really ugly cousin. You'd still pop her bubble wrap
Posted on: 2012/1/26 11:39
From Sydney, NSW
I'm also after a A series 5 speed to go behind an A15...
Posted on: 2012/1/26 11:18
Daily: 2000 Holden VX Calais 5.7L GenIII
Datto: 1972 Datsun 1600 L20B twin 40 DCOE Webers
From SE Melbourne
[end dad joke]
Posted on: 2012/1/22 5:11
Mildman, Datsunless
