Re: Diff swaps
The shim is to space out the 5mm larger H150.
When fitting the smaller you can either use an anti-shim, or none at all.
Posted on: 2012/1/12 21:38
Re: Diff swaps
From Perth WA AUS
H150 with shim will go into H145 housing, I have a H145 3.9 centre if you want it Mal ( as long as Mike doesn't still want it)
Posted on: 2012/1/12 11:25
Edited by levey on 2012/1/12 12:06:31
Datsun 1200 2Dr sedan.
Diff swaps
From Fremantle, West Australia
diff center swaps
I know you can slide an H145 into a 150 carrier (with a shim) but can you do the opposite?
want to put a 3.7 H150 center into a datto 1000 carrier
Posted on: 2012/1/12 11:11
