Re: A1200 Carby troubles
Not too shy to talk
running with my new $10 muffler
http://www.youtube.com/watch?v=I4U1_s ... 1T0g&index=1&feature=plcp
she coughed because I still had a little bit of water in the fuel tank from when I did more welding on it. (Put a third mount as it was vibrating too much with just two mounts, so drained it and filled her plum full of water so I could weld her safley. Only drawback was not being able to get all of the water out.
Runs like a top now.
Posted on: 2012/3/20 4:18
Not too shy to talk
more pics
jpg  18.jpg (191.04 KB)
1991_4f680386db164.jpg 1024X768 px
jpg  19.jpg (182.35 KB)
1991_4f6803c9c3dd4.jpg 1024X768 px
Posted on: 2012/3/20 4:15
Not too shy to talk
some pics
jpg  9.jpg (75.98 KB)
1991_4f6802f49fda0.jpg 1024X768 px
jpg  12.jpg (65.48 KB)
1991_4f68031304d7f.jpg 1024X768 px
jpg  14.jpg (67.22 KB)
1991_4f68032ce4d2e.jpg 640X480 px
jpg  17.jpg (114.00 KB)
1991_4f68034817b1b.jpg 640X480 px
Posted on: 2012/3/20 4:10
Not too shy to talk
Here is a link to the build thread on my A12 powered welder,
http://weldingweb.com/showthread.php?t=58549
I used a 1930's B17 200 AMP/28volt Generator for the welding unit. They used to be sold by surplus stores here for building welders after WW2
Posted on: 2012/3/20 4:02
From south coast nsw
pretty cool welder and she runs nice now,put a twin webber a15 in next ha....should post some pics up
Posted on: 2012/3/15 5:50
Not too shy to talk
Thanks for the link,
Set the float according to the sight glass and found that my main jet on the primary barrel was partially plugged. Cleaned it out and voila runs like a top.
Here is a progress video.....P.S. forgot to tell you guys, It's an A12 but its not in a car, it running my homemade portable welder! lol
http://www.youtube.com/watch?v=c91YHd ... 1T0g&index=1&feature=plcp
Posted on: 2012/3/14 3:28
From vic
Posted on: 2012/3/12 7:04
A12 Welder
Not too shy to talk
I got my carb all cleaned and put back together. I need to set the float properly. It's filling the bowl to much. Would this also cause the secondary throat to fill up with petrol even though the butterfly's are not open? I don't quite understand these particular carbs. Previous owner put an electric choke carb on it, looks like a A14 or A15 unit, does not have the electric solenoid for the fuel shut off tho. All help is appreciated!
Posted on: 2012/3/12 5:45
Edited by Kiwi_Canuck_B210 on 2012/3/20 5:03:11
