Re: Wanted: Oval port A15 twin carb manifold
From Townsville, Qld
Would this Old Bpro 45dcoe one I bought off one of our valued members here suit you at all? The porting (not mine) at it's largest is 40mm x 32, that's a little bigger than my JTS head so I didn't want to change that.
around 100-105mm deep
60mm from flange face to that cross brace
Posted on: 2012/4/30 8:49
Thanks for the responses everyone but a new one is out of my budget. Still looking for a used manifold.
Cheers.
Posted on: 2012/4/30 4:15
From sydney.nsw
i've got a brand new redline twin sidedraught oval port to suit. $280.00 + post if interested.cheers
Posted on: 2012/4/17 8:31
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
From Canberra
Hey mate if your wanting oval port A15 manifold brand new check out recarb.com.au
Thats where i got mine from :)
http://recarb.com.au/product_info.php?products_id=43
They have everything you could want for your carbies :)
Just give them a call and they will happily help and even give you the best settings for your carbs from the dyno sheets they have lying around
Posted on: 2012/4/17 7:57
From sydney
hi datsunbeginner,I have a redline ceramic coated manifold forsale.the manifold it self is fairly new and recently ceramic coated to keep engine temp down while gaining more power.
it also has been slighty ported.
if you are interested pm me.
thanks
Posted on: 2012/4/17 7:32
To suit twin Dellorto 40mm carbs.
Thanks.
Posted on: 2012/4/17 5:08
