Re: WTB single sidedraft maniflod for A15 please.
From Sydney
Pm,d il take it for sure.
Posted on: 2012/6/8 6:25
Cannon single-weber manifold for A15, $230 shipped to anywhere within Australia. PM if interested.
Does not work with the cast A15 exhaust manifold, but works with some extractors. It is very short, so you can use inlet bells or a full air filter with it.
Posted on: 2012/6/8 5:41
From Canberra
loosekid .the one you have,is a std type manifold with webber,or something different. can you put up pic on forum.cheers
Yeah its the original down draft manifold with webber out of a datsun sunny B310 that was on the A15 - only thing different is that the manifold has been nickel coated from a mate because i was going to use it but opt'ed for dual 45mm webbers with redline manifold
Ill take a pic when i get the chance and put it up for you to look at.
But as the topic states we are talking about a side draft (not the down draft that i just stated i had sitting around at the chance someone was interested in)
Posted on: 2012/5/11 10:05
Edited by loosekid on 2012/5/11 10:20:48
From Sydney
This is interesting as i have been given a good offer on a round port manifold
And i have an h89 head.
Posted on: 2012/5/11 8:15
From sydney.nsw
Posted on: 2012/5/11 7:21
Edited by bige on 2012/5/11 8:23:31
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
From Canberra
I got a A15 down draft one with carb if you are by chanced interested
But in regards for the side draft id give recarb a call as they have most things carby related and i just got my manifolds and carbies from them.
Just by luck they may have one or know where someone may have one.
http://recarb.com.au/advanced_search_ ... .php?keywords=a15&x=0&y=0
Posted on: 2012/5/11 7:01
Edited by loosekid on 2012/5/11 10:02:31
Edited by loosekid on 2012/5/11 10:03:09
From Freo
heya D, most of the H89 heads I have, have got the top middle hole in them already..
Posted on: 2012/5/11 6:27
A15 PSI Project Motor
'72 CB750k,
can the Oval port head be tapped for the missing hole as in the early heads?
just to confirm as looking at round port mani to fit oval port head just
needs the 2 top holes tapped into the oval port head.
Would need little buildup at the top of manifold for ports but plenty of meat.
Posted on: 2012/5/11 6:10
From Freo
Redline Weber
I see the single 40 isn't in the nissan list any more..
mabee send them an email..
Posted on: 2012/5/9 10:19
'72 CB750k,
From Sydney
Any tips on stockists? Or if they are stupid expensive?
Posted on: 2012/5/9 9:11
