Re: clutch problem part 2
Any oil leaks onto the clutch-? From main seal or gbox?
Might be time for experts
Posted on: 2012/5/18 5:21
From Brisbane
i haven't done anything since changing the master. pick up point has moved close to the floor, back out to near the top of pedal travel and back to normal. then slippage started and stopped.
just came back from drive and had some slip in 2nd again. i have thought about another bleed but i'm confident it was done well the first time.
Posted on: 2012/5/18 4:56
mmm bit strange so what did you do again? just pump the pedal? did it need a bleed maybe?
Posted on: 2012/5/17 12:30
From Brisbane
had the boot in!?
Posted on: 2012/5/17 10:28
We're you babying it a bit? If so give it a bit- might be the lining overheats? Just a theory.
Posted on: 2012/5/17 8:04
From Brisbane
see my clutch problem thread http://datsun1200.com/modules/newbb/v ... id=406438#forumpost406438
sorry to go on with this but after 2 return trips to work (100km)i have experienced NO slippage at all. pick up point is normal - good power down, feels great.
so what may have been causing inconsistant slipping in 2,3,4?? i haven't done anything wtf???
Posted on: 2012/5/17 7:50
